Since I'm no longer a "prospective buyer" I started a new thread.
Preparing for receiving my GT/22 and programming it.
I've got a few questions, about the manual and editor (Mac).
1. Editor > Presets > Show Page
According to the manual there should be a "Same" value. This doesn't show up in the editor. Is this because the GT is connected yet?
2. Editor > Global > Expression Pedals
My editor doesn't display some parameters in this screen. This is probably because the GT is connected yet?
3. Editor: screens
In some screens pressing Enter will exit the screen (i.e. expression pedals). In others it doesn't (Buttons, Presets, etc.). By design?
BTW, it would be very handy if Esc could be used to exit the screen.
4. Editor > Presets > Preset Actions
There's a System Step command in this menu. This suggests that a preset button can be used repeatedly to cycle between actions.
If so, how does this relate to the Global > 2nd Press feature? Does the latter (when enabled) have priority?
5. Manual > Axe-Fx setup > Slave mode
It says: "In this “normal” mode, if you want to change which effect blocks are turned on or off in a particular preset, you need to
do the editing on the Axe-Fx itself. You can’t update this information on the Mastermind GT."
I did not understand this at first. This indicates that no effect can be engaged/bypassed during regular use.
I guess that's probably not what's meant to be said, and that the text applies to saving states.
7. Where can one change the default bank size (number of presets per bank on the GT)?
8. If I change a preset title on the Axe-Fx, do I need to execute Get Preset Names?
9. There's no HOLD functionality for preset buttons, is that correct?
3. Editor: screens
