Nice Rack Canada
The After...
Built for a Jazz & Chamber Orchestra guitarist. Due to the super quiet stage volume of the chamber orchestra environment, the signal path and "noise floor" of the system had to be super quiet. Each effect pedal's mechanical switches had to be quiet as possible as well.
Mono Dynamic Effects into Stereo Modulation & Delay with Stereo Volume Control.
Buffered Split Dry line to RJM Music Mini Line Mixer for a "50/50" Parallel Blend of 100% Dry with 100% Wet Stereo Effects. Also buffered split to send signal to tuner constantly, provides a visual "cheat" for hitting certain intervals on a pitch bend, also allows for volume swelling a bent note while coming in on pitch with other players.
Clickless switching installed in Overdrives & Compressor.
Clickless Switching "External" Effects loop between Dynamics and Post Effects for easy insertion of extra effects into signal path.
Clickless Clean Boost of variable gain from unity to +20db.
Switching Circuit to sum Stereo Effects to Mono for Single Amp gigs, no re-patching, no signal loss, no phase issues.
Latching In & Out Connection points for Signal & Power to the pedalboard. The Amplifier I/O box features Switchable Ground Isolation Transformers for the Left & Right Amp Outputs and Clickless Relays for silent switching to Mute.
Updated system PSU with no "wall warts" for Strymon pedals.
Sync'd Tap Tempo from Time Line to Mobius.
MIDI Integration point for connecting the Strymon pedals to an external sequence/recording.
Set up and tear down time -2 minutes.
The Before
Mono Path.
PP2 v1 with "wall warts" for Strymon gear.
Switch to activate Tuner.
"Clicky" mechanical switches.
Tap Tempo into each pedal individually.
No external MIDI Integration.
Set up and tear down time 5+ minutes.
Nice Rack Canada
Custom Cables, Racks & Pedalboards - Engineered Solutions for Musicians
The Before
Mono Path.
Nice Rack Canada
