Clarktronics
Hi guys - I've been hunting down a ground loop in my board for the last two weeks which sounded like transformer hum bleeding into the cables - it would increase if my cables moved closer the the amp transformer or PSU. This would only happen when using the four cable method either through the PBC or an Eventide H90 (didn't test with any other pedal). Someone suggested putting a line isolator on the line that goes to the amp input - finally tried with a ground lift on a DI box as I don't have an isolator to hand, and the problem has been solved - no more transformer hum etc. I'm chuffed it's worked, but I'd quite like to know why! I tried the ISO B switch on the RJM from output 2, and lifting the ground on the send line with no result, it only works on the amp input line. Anyone got any ideas why this works? I'd like to know before I go out and buy a line isolator.
