Here's my rack that I am trying to put together. My Effect Gizmo's CS and Buffer Circuits seems to be not working properly at this time, but I am continuing to build it by just bypassing those circuits for now until RJM responds and tells me what to do and help me trouble-shoot why my EG if acting this way.
I discovered that the BUFFER Circuit was putting out or sending out low signals and that the CS Circuit had NO signal coming accross it or going through it. When I bypassed these circuits my signal from the FRONT JACK all the way to LOOP 9 SEND or OUT was get through LOUD and CLEAR.
Power Supply supplied with this Full Stereo Effects Gizmo is 9V 0.42A, would this be a reason for the low to no signal down the chain? Do I have a defective Effects Gizmo?
Signal Path / Switching Design : 2 Pre-Amp (On/Off/Both)
[2013-10-20 Final Wiring Design v8 Implementation] And so here it is all wired up as per Wiring Design (revision 8):
- Added a Korg PitchBlack Pro Rack Tuner, is on its way and will be installed where the Wireless System is currently located.
- The wireless system will be relocated.
- All power cables still be be installed.
[2013-10-20] Front View:
- Korg PitchBalck Pro still to be installed and Wireless System to be relocated.
[2013-10-08 REVISION NO. 8 WIRING DESIGN]
- Placed switching of Amps/PreAmps before any Loops/Effects.
- Added a RJM Mini Line Mixer to ADD PARALLEL Loop to control Effects that SUCK TONE.
Here's the updated design:
[2013-10-01 REVISED WIRING DESIGN] I've removed MIDI controllable devices that has "ByPass" via Midi from the Effect Gizmo's Switchable Loops and placed them between Loop Switches so that they are always in the signal path. I've done the same in one part of the signal path where I've place Channel 2 of the Alesis 3630 being used as a NOISE GATE before entering the rest of the Modulation/Reverb Effects Chain, this is always on. Channel 1 of the 3630 used as a NOISE GATE will be dedicated on Loop-4 after the TC Rottweiler to suppress the HighGain noise this pedal produces, when Loop-4 is off both the Rottweiler and the NoiseGate is out of Loop. By moving MIDI ByPassable effects such as my SA-170 EQ(s) and the TSR-24S off-loop, I free up and reclaim Loop resources on the Effects Gizmo for other pedals that would rely on the Effects Gizmo for remote On/Off.
[2013-09-19 WIRING DESIGN] includes MIDI Design - ACTUAL: I've removed the connections (Multi-Effects Zoom RFX2000) in Loop-11 and directly connected it into the Effects Loop of the Zoom 9150 since it could be ByPassed via MIDI. Freeing Loop-11 gives me 2 more dedicated Loops for extra stuff like control and signal mapping to 2 additional Amps or PreAmps.
Two PreAmps to create a wall of sound by activating Loop-9 and Loop-10.
On the First PreAmp (Carvin Quad X-Amp):
There are 2 Compressor processing loops (from an Alesis 3630 Compressor/Limiter/Gate) both in the first position of each Effects Chain (In-Front and After Clipping in Effects Loop) in Loop-1, and Loop-5 (I placed it first in the chain so that I can use the Gate if required and also amplify or boost the signal, also if required.) followed by the Programmable MIDI SA-170 EQ from Source Audio in the second position of each chain to change the tone flavor to whatever your heart desires.
Just need to test this design once it's all wired up and programmed correctly.
Notice all the old cables from the old setup just pile up on top. Am in the process of building this new/old system and making custom cables for this new setup.
Front of Rack
TONE: Carvin Quad X-Amp and a Zoom 9150 Tube Pre-Amp
EFFECTS: Digitech TSR-24S + Tokai Stomps, SA-170 EQ Programmable Midi EQ, Alesis 3630 Compressor, Dunlop CustomShop Wah and Digitech Whammy.
Rear of Rack
Still in the process of wiring it up.
Front of Rack
Rear of Rack
