In the new firmware included with the RJM Pedal Editor, I added a feature to the Overture: the ability to change how you select bank and presets. You do this by getting into setup (hold the On/Off button as you power it up, wait until the lights stop spinning), then turn the Gain knob. The On/Off LED will change colors based on the selected mode:
Blue (to the left): This is the normal bank and preset mode that the pedal is in by default. Pressing the Bank button will switch between the red bank (Presets 1-4) and the green bank (Presets 5-8). Pressing both buttons together switches to the next preset in the current bank
Purple/Pink (center): This is preset mode, which is the opposite of the above. Pressing the Bank button switches to the next preset in the current bank. Pressing both buttons together switches to the next preset in the current bank will switch between the red bank (Presets 1-4) and the green bank (Presets 5-8)
White (to the right): This is flat mode. Each press of the Bank button advances to the next preset, and when you reach the end of a bank, you switch to the next bank. So, if you pressed the Bank button multiple times, you'd go from preset 1 to preset 2, preset 3, all the way to preset 8, then bank to preset 1. Using the Pedal Editor, you can change the limit so that you can cycle through a different number of presets instead of 8.
Here's a quick video I did explaining further:
New features in the RJM Overture pedal
