rjmmusic said:
Do you have specific instant access buttons that control loops on the RG-16 and switches on the Mini Amp Gizmo and Y-Not? Programming will be different depending on whether you do or don't.
On the first page I have upper long row of buttons, each one for the RG-16 individual loop 1-6. Nothing in loop 7 or 8 at this time.
bottom row of buttons control RG-16 amp features 1 Ch Green ,2 BCh Blue, 3 Ch Red [ in Group 1] / 5 boost ch 1, 6 Boost ch 2and 3/ 7 effects loop Bogner 20th XTC
2nd row up from left ----> 1 Ch, 2 Ch, 3 ch [Group 2] Mesa Mk III Mini Amp Gizmo 2nd row 3 buttons on right side amp 1, amp 2, amp Both [Group 3] but for some reason when I use a button for both it turns on both then press again and both are off, and if both are on and I press one of the amp1/2 buttons it turns both of and I have to press it again to get either amp 1 or 2 on.
When I power up the MMGT 22 I have to press Page button to get it to go to Page 1 otherwise it does nothing. When I set up a 2nd page with "Preset" on bottom row it will go to page 1 when I press it?
On the Ground Control Pro I could load each device in a slot 1-16 and it seemed daily easy to edit each button so I could press 1 button and it would control everything. I know the MMGT is capable of that.... Im having a learning curve issue. Its me not the GT lol Each unit is under its own midi device number....RG-16 midi ch 1, Mini Amp Gizmo Midi ch 2, Y-Not Midi ch 4. That is all the Midi devices I have at the moment
All is backed up on thumb drive soooooo if you had a file for me to download with a few samples to open on the mmgt with 3 pages, a few presets and the RG-16 1-6 loops and mini amp gizmo and Ynot A/B AB functions still available
