Teel Merrick
I am toying with re-wiring my board to utilize the amazing effects loop in my 3rd Power Dual Citizen amp but I need help understanding how things interact and work together in PBC. The rig is mono and so is my board. I used the effects loop diagram from the PBC manual to wire it.
The pedals in the effects loop are the Caroline Meteore, TimeLine, Big Sky, and Neunaber Slate.
Question 1: I know on the big sky and timeline you can use the kill dry function. How does that interact with pedals that don't have that option?
Question 2: When using the effects loop, is it best to use the parallel option in the PBC?
Question 3: if one loop in the effects loop is set to parallel should all the pedals in the effects loop be set to parallel?
Question 4: how does the dry signal button under the settings page play into the effects loop setup?
Question 5: how do the three buffers interact with a setup like this? Should all three be on in this setup?
Thanks guys!
Thanks guys!
