boyce89976
@rjmmusic
Ron,
Based on this diagram, I think I know the answer but want to make sure. I'm about to incorporate a TC Electronic SCF (stereo chorus/flanger) into one of my stereo loops. I'm currently running a Tonal Recall (Loop 7 mono/series), Timefactor (loop 8 stereo/parallel), BigSky (Loop 9 stereo/parallel). My first thought was to put the SCF in loop 8 in stereo/series and move everything down one loop, but then the dry signal to the following loops would be the chorus/flanger effected output of the SCF.
Based on this diagram from the manual, I think it may be better to put the SCF in loop 10 in stereo/series, as it appears the wet signal from the previous parallel effects go straight to the line mixer after loop 10 (the only difference to the diagram is that loop 10 would be series). Is that correct?
Am I overthinking it?
Based on the above diagram, I believe this would be the signal flow with the SCF in loop 10:
Ron,
