PBC 6x and exp pedals
Bcmnsgy
I am using the PBC 6x and a mission expression pedal. When I use a stored exp pedal to try to send CC to my Source audio Collider or iK x-Vibe it does not control the appropriate CC parameter. But when I put it into the global exp pedal 1 the same CC codes change the appropriate parameter. For other pedals when I use a stored exp pedal it will change the CC of the appropriate parameter. Any reason why the global exp pedal acts differently than a stored one?
Hard to say without seeing your settings. How are you recalling the stored exp pedal settings?
I have changed the expression pedal override in pdl 1 to use the appropriate stored exp pedal setting and it seems to work better now. But I am including my setting for you to see.
  • pbc6.rjs
