[PBC/6X] Bug: outputs resetting when using inbuilt tuner
bornlivedie
When using the inbuilt tuner while having a preset active that only uses output 2 (currently only possible via the Mastermind editor), after deactivating the tuner suddenly both output 1 and 2 are active! After changing to another preset and selecting it again, the outputs are fine again (output 1 deactivated - output 2 active).
Demonstration: https://gfycat.com/essentialgleamingcardinal
bornlivedie
I've narrowed down the problem to the IA actions on the tuner button. Is there a way to preserve the state of the outputs #1 and #2 after the tuner is disengaged? Currently both outputs are set to ON when the tuner is disengaged.
Currently, there's no way to specify "go back to the way you were before". I'm trying to think of a solution for this...
bornlivedie
Okay, thanks for the feedback!
Currently I'm using a workaround, where I'm leaving output 1 and 2 OFF after tuning and then switching presets manually. After that the outputs are fine.
