PBC 6x turning the Insert Loop on and off for presets on the unit
Robert Payne
Hi, I'm sorry if this question has already been asked, but on the PBC 6x, if I use the insert loop for a 7th pedal, how do I turn it on and off for a preset without using the editor?
In other words, how do I turn it on and off in loop mode so I can quickly assign it to a preset on the fly?
The third button page has an insert loop button (labeled INS on the actual unit, on button 3 or 4 I think)
Piggybacking off of this inquiry, are you able to run the insert as a dual mono setup? If so, can you individually switch on each separate mono loop in the insert? Or does the PBC/6X only allow for turning on the insert as a whole?
Yes, if you split the insert loop, then it becomes two individually accessible mono loops. They can be turned on and off, and reordered independently.
