Gordon
I've had my eye on a Komet Ambikab Jr. (basically a powered stereo wet cab) for a while now, and thinking through a potential wet/dry/wet rig with my PBC before I pull the trigger. Seems like there are some limitations though, and I'd welcome any input. My current signal path is:
Guitar -> Fuzz -> Wah -> PBC
L1: envelope filter
L2: comp (Jackson Audio Bloom -- boost/eq controlled via midi)
L3: OD
L4: OD
Out 1-4 -> volume pedal -> In 5-6
L5: univibe
L6: rotary (Strymon Lex)
Out 5-6: amp input
In 7-10: FX Send
L7: tremolo (mono)
L8: delay (Strymon Timeline)
L9: reverb (TBD)
L10: looper (Pigtronix Infinity Looper - stereo capable)
Output A/Left: FX Return
Output B/Right: amp 2 (wired to junction box on pedalboard for input but not currently used)
I'm just not sure wet/dry/wet makes sense with this setup. Following the PBC wiring diagram, it looks like I have to send all 4 loops from 7-10 to the Ambikab, which is wet only and doesn't see any dry signal by my understanding. Ideally, however, I only want to send delay and reverb, and run them in parallel. It might be cool to swap tremolo and rotary to take advantage of the Lex's stereo capabilities in L7, but I would miss out on having the dry signal running into it, which I would definitely miss. Then there's the looper, and I have no idea how I would ever be able to loop both the wet and dry paths via L10. The looper really belongs in a loop too because when I'm not using it I want it completely out of the chain.
So, is there a way to only send loops 8/9 to the Ambikab, and still be able to loop both wet and dry signals, or have I found the ONE use case for which the PBC isn't best-suited? Thanks!
L1: envelope filter
L3: OD
L4: OD
L5: univibe
Out 5-6: amp input
In 7-10: FX Send
L7: tremolo (mono)
L9: reverb (TBD)
