Running Two Amps out of PBC and even with dry signal, the JC 120 seems to be drastically attenuated, getting much lower volume than it should any clue?
Switches are set to Mono, Effects are in loops 7 and 8 are mono. A delay and chorus but only using Mono outputs on the pedals. Also this is happening with all loops off and just going clean to the amp.
I am assuming there is no way in the editor to access the line mixer?
I also tried swapping outputs and it is only happening on Jc120 on either output and not Blues Jr .
Trying to find a solution before the artists set in a couple of hours :&
Are you sure your amp and cables are good? If the JC120 isn't working on either output, and the other amp is working on both, the outputs have to be ok.
The line mixer inputs are controlled by the series/parallel setting on loops 7-10 and the dry mix setting.
Figured it out, was a bad joint in my guitar in passthrough connector the one connection I mistakenly overlooked. Whew. Thanks for the help, yall are great over here.
