PBC FN Switch Mesa Fillmore
Sp4zRX
I want to use the Hold feature on the PBC/6x to change the Channels on my amp. I am using a Mesa Fillmore 25. Do these setting look correct? I am not sure if I should use 'Momentary'. I am also not sure about the 'Number' value of the action.
I just want to make sure I have it right before I plug in the amp and blow it up!
It won't harm the amp no matter how you have it set, don't worry about that. There's only one thing you might want to change: If you want to be able to program the button to automatically switch the channel, so that when you change presets on the PBC, the amp channel changes as well, then turn on Send on Preset Change. Otherwise it looks good. Don't turn on Momentary, that would switch to the second channel only for a split second, then switch back.
