vatore3rd
With FW 5.0.0 I've notice an issue with IA Cycle Actions Step 0 on preset change that I don't recall having before. I know the IA button works properly -- if I am in IA Mode and I cycle the button all steps / state work correctly. I have IA Link disabled on this button (although enabling it doesn't address the issue), and Send On Preset Change and Update State On Preset Change are enabled.
The problem occurs if I have a preset in which I have never pressed that particular IA Cycle button (and thus it is presumably at Step 0 by default). In the past, I seem to recall that would result with the system state matching Step 0 state when that preset is activated. But now, the state of the system does not match Step 0 when the preset is selected even though the button color matches Step 0.
Things work if, for every preset I want Step 0 active, I cycle through all the steps of that button to get back to 0 and then save the preset. Alternatively, I can set up the default state of things (fn switches, exp pedals in this case) to match Step 0. So I'm not stuck here. Just trying to understand if the system is behaving as expected now or if something changed in recent firmware updates.
