Rick in TN
I have never used my PBC for midi control of anything. Only used it as IA/loops thing. Now I have several PRESETS set up on the PBC and I want to control my Time Factor to where it will change to different preset with different PRESET chosen on the PBC.
I've looked at every video demo more than once. Read thru both manuals. Never found a video discussing the Time Factor but several with a Strymon Timeline. They should be similar I'm sure. But no-go so far.
No matter what I've tried so far it doesn't make the Time Factor do anything. My midi cable is good. The Time Factor and the PBC are set to Midi Channel "1". The Time Factor is set up in the PBC Editor as a device (the only device). The PBC loaded all the Time Factor defaults into the PBC setup.
All I want would be to when I step on PBC PRESET #1 it loads the chosen preset in the Time Factor. Step on PRESET #2 on PBC and it causes the Time Factor to load the chosen Time Factor Preset....and so on. But it does nothing. PBC loads the correct LOOPS I saved to that PRESET. But does nothing to the Time Factor.
I feel like a setting on the PBC is incorrect maybe. The default Time Factor is OFFSET "1" where when I look into the settings on the Time Factor itself it has the 1st preset as "0". I tried changing PBC to "0". But that does nothing either. Would there be any setting on the "MIDI" page of the PBC I need to set differently. All I need is midi messages to be sent from the PBC. Need no midi-thru or merge (I don't think).
Help please.....
Help please.....
