ChrisConteGuitar
Hi Ron,
One more issue I’m struggling with. I can’t seem to fix it on my own. As I mentioned previously, I recently uploaded the latest firmware and I’m using the new editor.
Preset “Show Page” edit
I have roughly 160 presets all assigned to songs. Typically, when I switch songs I can hit any one of the assigned presets and it will execute that preset and stay in “preset mode”. However, I now have an issue where by when I press a preset, it executes the parameters of that preset but the immediately switches to “Loops” mode. I obviously want to stay in preset mode. I’m not show why or how this is doing that. I’ve done some troubleshooting with features I normally don’t mess with.
First, do you have any idea what is going on? Secondly, can you explain further how the following functions work? I can’t seem to understand how they function even after reading the manual. Changing settings and enabling these setting doesn’t seem to do anything.
PRESET TAB
1.) Show Page (at the top) - I assumed that you can assign which page will be display on the PBC (i.e. 1=Presets, 2=IA Loops, 3=Switches, etc)
2.) Local Page (at the top)
3.) Display preset’s default page (at the bottom)
Help?
I noted this statement in the "Show Page" section of the online manual.
Show Page - Selects which button page should be displayed when the preset is loaded. Please note that this setting has no effect if Auto Page Select in the Globals Tab is not turned on. Possible values are:
PRESET TAB
Help?
- 1-16 - Displays the selected page
- Local Page - Displays the local button page (if Local Page is turned on)
- Same - Stay on the same page - don't change pages
