Brian Watson
Hi guys, first post and I'm a new user on the PBC. Love it so far, learning as I go.
I'm tech for a band using the PBC on guitarist's main pedal board, and recently we've been running into an issue where the PBC will randomly "lose" the output signal when switching presets. It's been a bit of a nightmare to troubleshoot, but today I've had the chance to test cables from guitar to board and out to amp, individual pedal switches and cables in/out of loops, and everything is good, nothing seems intermittent.
After playing through the PBC for about an hour, working up and down banks and presets, in both preset and loop modes, I was able to twice re create this problem where the output signal disappears when selecting a new preset. I could not isolate the problem to one particular bank/song, preset, loop, or switch on the PBC. Hitting tuner mute/unmute a couple times or power cycling the PBC seems to be the fix.
Has anyone else run into this, been able to recreate or trace the problem, or found a fix? It's just started happening during the past week, 2 shows in a row, and otherwise has been flawless. I suspected everything else in the pedal chain, cables, etc. first. This unit has been in use for a bit over a year and has been all over the US and Europe for about 100 shows, but it's in good shape and hasn't taken any obvious hits or dings. We are running a slightly older version of the firmware and editor bc the guitarist has an older Mac, at least that's the reason I was given.
Thanks for any help or pointers,
Brian
Brian
