Hello All. New to RJM Products. Searching through the forum I can see this is a very cool community.
I have been using GCX and Ground link in a couple of basic W/D/W setups where it was setup as IA only.
I will be using the PBC10 on a pedal board for front end effects and amp channel switching only.
I have racked and rack shelved my stereo effects that will only go to the Wet speakers. I have another shallow rack shelf that I'm thinking of buying and placing the MEGX on along with a power supply.
I would be placing the pullout rack shelf with pedals underneath the MEGX and power supply rack and a couple of older rack units like ADA STD1 and PCM 42 underneath the pullout rack shelf. Currently the only midi controllable device will be the H90. Reordering of effects is not a priority of mine although I see that it can be done on the MEGX.
I have the below questions and if anybody can help out that would be great.
1) I looked through the forum and I see the PCB10 can't display what is happening on the MEGX. Can the PCB10 still switch on and off It's loops along with the loops in the MEGX for a one switch preset on the PCB10?
2) If above ? 1 is possible.... Can the PCB10 also recall presets in the H90 and combine it along with a one switch/step preset?
3) I would still want the dry (including or not the front amp effects) to flow through The wet speakers or into the MEGX. Pretty sure this can happen. Just need confirm.
4) Can the MEGX handle the amp switching and boost switch (amp has a 1/4" boost input for leads ). This will prevent another cable running from the pedal board. Thinking I would only need the one mono sgnal ( front end effects are all mono) and a midi cable to the MEGX.
Hopefully these aren't redundant questions. I did look through the forum. Apologies ahead of time if the answers are out there.
Thanks,
Rhyno
Thanks,
Rhyno
