Hey there,
I bought my Mastermind PBC 10 in 2020 and have just experienced the problem that the "5" switch does not work any more. When I press it, the selection stays with the last switch I pressed.
I opened the unit to check whether I could identify the problem and found the following:
1. When "idle" the spring responsible for triggering the metal plate beneath it is not touching the metal plate, but it seems to be close enough to depress it when I use the switch. I don't know if the force is really enough, but the other switches have varying degrees of spring height, too, with some touching the metal plate and others being in a similar position as switch "5". Is it necessary/possible to tighten the spring?
2. The plastic retainer holding the plastic tube for the LED indicator has come loose from the backside of the casing, so that the tube sits slightly askew and the LED has stopped functioning. I don't know if it was glued on, but I am unable to reattach it by carefully probing it with a toothpick from the outside. Does a malfunction here disable the switch as a whole or is it just coincidence?
Any help would be appreciated and I hope a solution can be found without sending the unit in.
Best regards
Best regards
