TX6Strings
Hello - Is there a way to turn off/on the buffer in the insert loop of the PBC6X?
Thank you
Thank you
It's part of the insert loop, so turning off the insert loop turns off the buffer. Moving the insert loop also moves the buffer, and the position matters. Sometimes a little, sometimes a lot. Depends on what you have in the other loops.If you’re not using the insert. Does it need to be on for the buffering benefits? Also does placement matter?
As long as you keep insert loop 2 turned off, it will pass signal. If you turn it on, it'll mute. You can lock insert 2 in the off position to prevent this.@rjmmusic Sorry to hijack this topic a bit but I have a slightly related question. I have customer with a rig I built for him that likes a buffer after his fuzz (it brightens it up a bit).
If I split the insert loop (insert loop 1 has a pedal) and leave insert loop 2 with nothing plugged into it, will it pass signal? My thought is to leave insert 2 on at the end of his chain as an output buffer of sorts. Or will I need to just connect the send to the return of that loop to do this?
But cuterigs' use case here was to engage the buffer (after a fuzz)?As long as you keep [split mono] insert loop 2 turned off, it will pass signal.
I believe the buffer is always on in the insert loop itself and there’s no option to turn it off. Turn on insert loop and the pedal in that loop gets a buffered signal (presumably for long runs to say, an amp effects loop or maybe a volume pedal that tends to suck tone). You can’t turn the buffer off in this loop so you don’t want impedance sensitive pedals in the insert loops.Apologies for necro-threading this, but I'm a bit confused here. I'm considering the PBC/6X for another rig and would like the option of disabling the insert loop buffer (I'll have at least one always-on pedal with a high quality buffer).
On the one hand:
On the other hand:
Just trying to understand exactly how this works. Thx!
