cuterigs
Hey, @rjmmusic and everyone!
I have a customer that wants to get a PBC6X. He has an EHX Pitchfork Plus pedal that has two outputs. He wants to be able to run one pitch to one amp while the other amp is dry or two pitches, one to each amp.
The Pitchfork + has a single mono input and then a main output along with an "aux" output that can be assigned to different effects in the pedal.
Could this be setup with the PBC6X? Would it just be Loop 6 (for example) send with a mono cable to the pedal in, then TRS insert cable on the return? Would the main output (wired to tip of an insert cable) go only to left and the aux output (wired to ring of an insert cable) only go to right? Or are outputs maybe assignable?
Thanks for any help!
jg
jg
