cuterigs
Hello!
I am working on a build that has me stumped a bit.
He uses a Vox AC30 with the two channel inputs (not a channel switching amp like a Mesa, but rather the old school two input style channels).
he wants to use the PBC6X to switch between the channels (so outputs A/B or both on the RJM). The hang up I have is that he also wants to use the amp’s fx loop to run ambient effects (in PBC loops) to the loop and drive effects to either of the amp’s inputs.
so as far as I know: this defeats 4 cable method with the PBC insert loop? If it was a single channel amp, this would be fine. But since the main output of the PBC has to be used for the amp loop return, how do I use the insert send to switch channels?
can I run it as a stereo loop and have a stereo send to the two channels and mono return (from the amp loop)? But then this is both amp channels always on right? We can’t select L or R send only?
so do I run the insert in mono split, so two inserts. One send to the cleaner channel, one send to the dirty channel. But then what of the amp’s effects loop send? How do I get that into both the inserts?
any help would be greatly appreciated!
