LeeB
I posted this question in another thread I had made. I haven't made headway though and thought there might be some people who could help me out. I'm going to upload a video as well, sorry about the mess, as you'll see I had cables going all over the place to try and suss it out.
I have a Catalinbread CSIDMAN that does not want to play with the PBC. I've emailed Catalinbread and they responded quickly.. then after I gave some more detailed info they went radio silent. I've tried following up a couple times with no luck, so maybe someone here can help.
When the pedal is bypassed, my signal is normal. I have a lot of cabling running so I have all 3 buffers and a boss as a buffer in the mix. When the pedal is activated it makes my signal sound exactly like it sounds when I turn off the first buffer. I'd originally started with the pedal in Loop 1. I tried multiple loops (only 1-6 as 7-10 go to my FX loop) and many different cables/lengths. The same thing happens every time. That said, if I place it outside of the PBC it works fine. If I stick another pedal in place of the CSIDMAN, it works. I've also tried different power supplies just in case.
This is my setup:
Guitar-->Neutrik 1/4"-->Whammy 5->Ernie Ball Volume-->PBC Input (Buffer Engaged)
Loop 1 - CSIDMAN
Loop 2 - 535q Wah
Loop 3 - N/A
Loop 4 - N/A
Loops 1-4 Output-->Loops 5-6 Input
Loop 5 - Big Muff Op Amp Pi
Loop 6 - Tuber Screamer
Loops 5-6 Output-->Boss DD-5-->Radial Bigshot ABY-->(2)Neutrik 1/4"-->1 Orange and 1 Marshal head
FX Loop Send from the Orange head-->Neutrik 1/4"-->PBC Loops 7-10 Input (Buffer Engaged)
Loop 7 - Rotovibe
Loop 8 - Phase 90
Loop 9 - BF-2
Loop 10 - MF Delay
Loops 7-10 Output (Buffer Engaged)-->Timeline Delay-->Neutrik 1/4"-->FX Loop Return to the Orange head
I love this pedal. I wish it would work out. If it doesn't, it doesn't. Any thoughts? Thanks
Video: https://www.dropbox.com/s/v00wejzzorb8be5/20200523_145410_1.mp4?dl=0
This is my setup:
Loop 1 - CSIDMAN
Loop 2 - 535q Wah
Loop 3 - N/A
Loop 4 - N/A
Loop 7 - Rotovibe
Loop 8 - Phase 90
Loop 9 - BF-2
Loop 10 - MF Delay
