Hi Ron,
Sorry to do this but I've got a different issue now.
SCENARIO - I have a GT22 connected to the RJM phantom power box using a 7 pin midi cable supplied by RJM (lets call it midi#1). The phantom power box is also powered using a power adaptor supplied by RJM. The phantom power box is then connected to my Axe FX XL with a short 1m 5 pin midi cable (lets call it midi#2). Nothing else is connected to the GT or the Axe.
Connecting the GT directly to the Axe using either midi#1 or midi#2 & bi-directional midi works great. All presets are read by the GT & the Axe tuner works as expected. Both midi cables perform 100% as expected.
Re-connect everything to the phantom power box & the GT cannot read Axe presets or read the Axe tuner. The GT will change channels on the Axe, so midi out from the GT/phantom power box appears to be working however there is no midi coming back to the GT to enable the tuner function or read Axe presets. Bi-direction midi has stopped working! The only difference is the phantom power box.
Hoping you have a tip to solve this?
