Pod HD Pro X IA/CC Issue
Hi All,
I am adding a Pod HD Pro to my setup and am having trouble.
I have set up the GT and the Pod and it is responding to program changes. I've added the buttons for the footswitches and I can turn effects off and on from the GT. Its when I call up a preset, the stored IAs are not changing the correct footswitches on the Pod. If i press the preset again they change but it's still not correct. Any ideas?
You probably need to activate, in the device, "Send CCs on preset change" if you want it to function in that manner. Or your IA switches might not be triggering on preset change.
Thanks for your reply. No, I have tried that and it doesn't work.
I do know my IA switches are working because I can go to the
button page and turn them on and off. It only seems to happen
when recalling presets. Any other suggestions are welcome.
I mentioned this in email, but I'll put it here for everyone else:
From what I remember, you need to turn on "Send on Preset Change", "Only Off Msgs" and "Update on Preset Change" on all buttons that control the POD HD effects. You also need to set each preset in the POD to have all effects turned off by default, and rely on the GT to turn on the effects.
I know that this didn't get you a working solution yet, but we'll figure out the missing puzzle piece. Hopefully a POD HD user will chime in here with more info.
