Hi;
Anybody using Mini Amp Gizmo with a Line 6 POD HD ?
I'm having an issue getting my HD500 to switch my amp channels via the Amp Gizmo.
Looks like the Gizmo is set up correct because when I manually click the switches 1 thru 8 it turns on each channel and/or effect properly. Therefore, the problem must be in the HD500 setup.
In the SETUP view, I have MIDI CHANNEL set to 1 which is the default on the Amp Gizmo.I have MIDI OUT/THRU set to OUT.
Is there anything else I need to set on the HD500, have I mssed something ?
BTW, I spoke with Line 6 Tech support, not much help there.
