Pod line6 x3 live Mini Amp Gizmo and 4 method cable
riffman01
Hello everybody, i need help with this,
I need to know the right way to connect a Pod line6 x3 live with the Mini Amp Gizmo using the 4 method cable, i already have the custom cable made by RJM for my Soldano Decatone, Thank you for you're help! Riffman01 :)
Here are the connections you need to make:
X3 MIDI output to Mini Amp Gizmo MIDI input
Mini Amp Gizmo "To Amp" to amp's footswitch jack
Guitar into X3 input
X3 send into amp's input
amp's loop send into X3 return
X3 output to amp's loop return
That should do it...
riffman01 said:
Great i will try this and thank you for the quick reply, take care! riffman01
Hi
Remember that the fx loop of the pod is line level and you dont want to feed line level to your amp guitar input.... make sure you put someting in between that put the level down... and put the x3 live outs to line level as your amp's fx return is most possible line leve (check with your manual)
