Possible to change samme CC on multiple IA´s?
Hi there
I don´t know if this is possible - but I have an old rack effects where I have stored about 100 presets.
For different reasons I need to change the CC i use to switch the effect on (loop). I need to do this for about 100 times if I should do it the way I know..
Is there a way so I can only do this once?
Thanks
ReidarNikolai
Unfortunately, there's no way currently to do a search and replace type function.
However, if in the future you use Macros, large changes like that are easy. On your IA buttons, set it to call a macro, and have the macro send the CC (or whatever else needs to be sent). If you have multiple IAs calling the macro, then you'll only need to change the macro if the CC message needs to change.
I guess I will start using those macros at once.
Next time there might be even more switches that needs changing :)
Thanks Ron - as always: very good customer service.
Reidar
