electroncr
RJM,
I have just purchased my Mini Amp Gizmo and appreciate your products. I have gotten it working, but I have an issue trying to get it to power off my Modtone 'PowerPlant.' The PowerPlant supplies 9vDC/150mA, exactly what your documentation says is needed for the Mini Amp Gizmo. When I first tried it, the "Write" button would light up green, but would not function. It would not respond to any button presses or Midi commands. All the sudden, it worked. After some debug, I have found out that it will work right after I power it using the supplied power supply. In other words, if I try to power it with my Modtone in the morning, it will not work until I power it first with my "RJM Power Supply," remove the power, and then plug in the Mini Amp Gizmo to the PowerPlant immediately after. I would rather not do this, if possible. Do you know if I am doing anything wrong or how I can alleviate this problem?
Thanks,
Nick
Thanks,
Nick
