Preamp MKii not tracking well midi via expression
Pieutr
Hi Everyone,
I have the Preamp mkii fully controlled via midi thanks to the RJM PBC 6x switcher.
My expression pedal is the Mission engineering rjm SP-1
The Preamp has a hard time tracking expression via Midi, whereas when i plug the expression straight into the EXP input of the pedal it works much better. Unfortunately I cant do this since i use my expression output to go the the PBC so as to control other pedals.
No expression tracking problem with other pedals (Bloom, and H9) via midi.
It wouldnt be much of a problem if the sound was as intended and if it were only the faders not tracking until the programmed spot but unfortunately the sound is also stuck with the faders.
Please find attached a screenshot of my preamp midi settings in the device tab.
Please let me know if there's anything I can do about it.
Thanks a lot.
Pierre M.
If it works well with other pedals, then probably the issue lies within the Preamp itself. I recommend asking Chase Bliss if they have any suggestions
