spikeymcspikeface
What appears to be a random glitch has just crept in ...
I'm running firmware 3.1.5 with latest editor 3.1.6 (as far as I can see there isn't a firmware 3.1.6 to match the editor version ...?).
I've been tweaking a few patches, mainly changing which loops a few PBC pre-sets call up & adjusting some expression pedal settings (so nothing global or to do with the system settings or anything else particularly significant), and for no apparent reason today the pre-set lights on the PBC stopped turning off with the pre-set (so the light above a given pre-set is in the off colour, I choose that pre-set, its light goes to the on colour, but when I press its footswitch a second time to de-select that pre-set the light stays in the on colour until I choose another pre-set ... where-upon the same thing happens to that pre-set ... and it's the same for every pre-set). I can switch between any pre-set and the global setting (as per second switch settings), it's just that any selected pre-set light stays in the on position until a different pre-set is selected.
I had been rolling back to my previous .rjm settings file to fix the problem, but each time I did that I found that once I began editing the patches again, at some random point the same glitch will suddenly start up again - not necessarily at the same stage of my edits (so it's not as if it's happening each time I make a particular change to any settings - it seems completely random as far as I can tell ...). However, I've just tried to reload that original file and (nightmare) for some bizarre reason it's stopped fixing the issue - and no, I had accidently overwritten that .rjm file, I'd been obsessively NOT saving anything in the editor because I was paranoid I wouldn't be able to fix things ... so I'm now at a loss to know what to do. (And please don't say factory reset - I play with 4 bands, each with long set lists, generating at the last count 44 different pre-sets ...)
HELP ...!
HELP ...!
