Preset Menu selection reverts back to Previous Preset. GT 22 Axe FX III
Discussion in 'GT General Discussion' started by UncleMatt, Dec 14, 2019.
  1. UncleMatt
    UncleMatt
    Dec 9, 2019
    17
    1
    When I select a preset from the "preset menu" page it will not change, but reverts back to previous preset.
    - I can change the preset manually on the Axe FX III and it will update on GT 22.
    - On preset menu page the currently selected preset is "on", but will not switch to a new preset.
    I am new the GT so I am sure I am missing something simple. Thanks for any help!
  2. UncleMatt
    UncleMatt
    Dec 9, 2019
    17
    1
    I thought I fixed it, but its reverting back again to previous preset.
    #2 UncleMatt, Dec 14, 2019
  3. UncleMatt
    UncleMatt
    Dec 9, 2019
    17
    1
    See what is happening here:
  4. rjmmusic
    Staff Member
    Jan 18, 2010
    6,439
    1,163
    Does the MIDI channel set in the Devices tab of the GT match the MIDI channel set on the Axe-Fx's MIDI settings?
  5. UncleMatt
    UncleMatt
    Dec 9, 2019
    17
    1
    Yes both are on channel 1.
  6. UncleMatt
    UncleMatt
    Dec 9, 2019
    17
    1
    #6 UncleMatt, Dec 14, 2019
  7. rjmmusic
    Staff Member
    Jan 18, 2010
    6,439
    1,163
    When you select a preset from the preset menu, does the Axe-Fx change briefly to the requested preset, then back to the previous preset (like the GT screen does)?
    Also, make sure that PC Mapping is turned off in the Axe-Fx.
  8. UncleMatt
    UncleMatt
    Dec 9, 2019
    17
    1
    No, the Axe-Fx screen does not change.
    PC mapping is off.
    #8 UncleMatt, Dec 14, 2019
  9. rjmmusic
    Staff Member
    Jan 18, 2010
    6,439
    1,163
    It seems like the GT is not changing the Axe-Fx preset for some reason, then Poll State is correcting the GT''s preset to match the Axe-Fx. Try turning off Poll State in Devices on the GT, and see if you can get the Axe-Fx to change presets.
  10. UncleMatt
    UncleMatt
    Dec 9, 2019
    17
    1
    I turned off “poll state”, the GT changed preset names (via the preset menu), but was not switching the Axe-Fx III.
  11. rjmmusic
    Staff Member
    Jan 18, 2010
    6,439
    1,163
    Ok, so that is the problem for sure. Is the GT successfully controlling other things on the Axe-Fx, like effect blocks?
  12. UncleMatt
    UncleMatt
    Dec 9, 2019
    17
    1
    Yes, effects blocks work fine. Looper works. Just can’t change preset.
  13. UncleMatt
    UncleMatt
    Dec 9, 2019
    17
    1
    I used the "get preset names" 0-20, but it went to I (I think) preset 123 and loaded them at the 00 preset. So now it has loaded the names wrong out of order.
    I wanted to share this in case it helps diagnose what's going on... very weird. I just want to access presets.
    At what point do I factory reset everything? Or will I still need to trouble shoot this?
    #13 UncleMatt, Dec 15, 2019
  14. UncleMatt
    UncleMatt
    Dec 9, 2019
    17
    1
    I did a factory reset, and reloaded original page settings (@iaresee thanks for sharing) and the preset menu works again. I loaded my custom pages back and its doing the reverting to previous preset again. I made a change somewhere that is making it act up... I can't find it, so I guess I am just going to start over.
    Not a huge deal, but very curious what was causing this to happen.
  15. UncleMatt
    UncleMatt
    Dec 9, 2019
    17
    1
    SOLVED (I saved each page separately and loaded them one by one until the issue was uncovered).
    Page 6 was the culprit. I was experimenting with using external switch 1 to be a global preset selection, not sure why it caused the problems it did... Hopefully someone smarter then me can explain what is going on.
    Here is what is selected:
    ExtSw 1
    Normal
    IA
    IA settings:
    on - send on preset change
    on - update on preset change
    IA Actions:
    Axe-Fx III / PC off: 0 on:2
    iaresee likes this.
  16. rjmmusic
    Staff Member
    Jan 18, 2010
    6,439
    1,163
    Send on Preset Change is the culprit. When it's turned on, it'll send its message(s) every time you change presets, so it's jumping back to preset 1 every time you change presets, then Poll State makes the GT follow the Axe-Fx's preset change.
    Sorry I missed that before - I should have caught that in your settings.
    iaresee likes this.
  17. Andrew Slotta
    Andrew Slotta
    Dec 18, 2019
    1
    0
    What do the settings need to be because I am having this issue on mine now after updating the other day and I have a gig on Saturday.
  18. UncleMatt
    UncleMatt
    Dec 9, 2019
    17
    1
    @Andrew Slotta I checked "send on preset change" on one of my button's (on a different page) that had an IA action to go to preset 1. When I made a preset change it also triggered this other button to make the change, thus reverting it back to preset 1 no matter what.
    I would go through your buttons page and see if that is checked anywhere and sending a conflicting message.
Share This Page
