presets midi actions question
BasV1976
I'll try to keep it short and in my best English...
THe problem I have is with the 2 H9's.
For example: I'm in a preset on the LT. I change a preset on the H9 without using the LT, If I then change a preset on the LT which has the same action as the former preset, the H9 doesn't change.
preset 1:
H9 left/ PC on:1
H9 right/ PC on:13
preset 2:
H9 left/ PC on:1
H9 right/ PC on:14
Does it make any sense what I'm trying to tell?
I guess the answer will probably be shorter than my question.. :)
I know what you mean - turn on Send Redundant PCs in the Mastermind's Devices settings , for your H9 devices. This will make it send a PC on every preset change, even if it was the same one as the last time.
Thanks! I just found out I had it only active on the other H9.
