Presets & songlist
Gazlyn
Hi,
Im running my PBC 6x in song mode and have the presets as is and have no issue switching between songs and presets in the songs, I have been recently watching the videos and on been playing around with cycles and IA presets. When I do this it after a certain no of IA buttons set in a preset it stops setting the correct preset.
My normal setup.
Song 1
Button 1: Preset 1
Button 2: Preset 2
Button 3: Preset 3
Button 4: Preset 4
Button 5: Preset 5
Button 6: Preset 6
Button 7: Preset 7
So if on button 3 (Preset 3) I have button 5,6,7 configured to preset 8,9,10 it won't work properly.
Basically if I set all my button in my presets to IA it won't change songs or recognise my ccs that I'm sending out to my HX. Though if I use the default buttons it works fine though I then can have the flexibility that I'm looking for to have extra presets in my song.
You can't have a gap in presets within your preset buttons - preset buttons always take the lowest available presets. You can change the order of how the presets are assigned to buttons, but you can't specify that a certain preset number should be skipped.
Does that mean that if he wanted to use IA Cycles to access presets 8, 9 and 10 for this song, he could do that on button 7? Learning about IA Cycles myself and stumbled across this thread.
You could set up an IA Cycle button to select specific presets (example: "load preset #72"), but not "load the 8th preset in the current song". This is probably something I should add at some point.
