Mark Burton
Apologies if this has been asked before but advice needed
I've had a Rocktron All Access for years and had it setup as the bottom 5 for PCs and channel changes on my Diezel amp and top 10 for CCs so adding effects to it
For example, if I was on button 2 (preset 2 so channel 2 on the amp and nothing else) and would add effects to it, then would press button 2 again it would clear all the effects I added as it goes back to the original preset, this has also worked on other MIDI controllers with PCs and CCs
I've now got the GT22 and have set it up the same but when I press the same PC button it doesn't do anything to the CCs
Can this be changed please?
Obviously the GT22 is the best MIDI pedal I've owned and will do an awful lot more than all of my other pedals so this is only a minor thing
