Kamil Rustam
I have a big guitar pedalboard that is used with the PBC Mastermind controller
( I have a timeline, Mobius, H9 etc..that are all chained in a midi setup controlled by the PBC Mastermind)
-I use the PBC as a master midi clock with all the midi pedals for most of my presets but I disable master clock (Tempo 0.00) on one preset I use to be able to use the midi tap for my Mobius (CC#93 but I also tried with CC#81) as a speed selector for the rotary FX speed in my Mobius and (Midi clock is set to Off in the Mobius Global settings)
It works great and I can go from slow to fast in the rotary FX by pressing on that switch ...
I have a big problem though :
-if, in my PBC, I go to that rotary preset coming from a preset in my PBC with 0.00BPM clock (From the PBC Mastermind , then everything works fine ( I can control the rotary slow and fast with the midi tap tempo switch of the PBC or tap from the Strymon multi for that matter)
But If, in my PBC, I go to the rotary preset coming from a preset with any clock tempo set, for some reason, it disables the tap tempo switch (on the mobius and on the PBC) and if I press the tap tempo switch now , the rotary slow and fast setting doesn't work neither on the PBC or the Mobius itself (I even tried with the Strymon Multi) .
The only thing that will make it work again is to
1-manually press on the preset button to reload on the Mobius rotary preset
2-select a preset on the PBC with no tempo (0.00bpm) first and then going to the rotary preset with no tempo. The tap switch (On the mobius, Multi, or midi) will work again
I have no idea why sending midi clock over midi to another preset will disable tap tempo on that preset? ( Especially since I disabled Global midi clock receive)
Now if I set the Global Midi clock receive to on, it will work but it adjusts to the tempo so I don’t get the Leslie FX If I dont have a tempo set higher then 400 bpm ! and also it puts all the other pedals to a very high tempo unrelated to the song I’m playing . so not very usable
Any Idea?
Thanks in Advance
~Kamil
Any Idea?
Thanks in Advance
~Kamil
