Hello, I am using fryette ps100, 2902 and rjm pbc10 to build a stereo system. I meet a issue.
My signal chain:
pbc10 loop 1-6, overdrive and distortion pedal,
pbc out 5-6 -> Matchless Hc30 input, HC30 amp out->fryett ps100 amp in,
ps100 send-》suhr buffer(split 2 signal),one to pbc10 input 7,one to ps100 return(dry signal),ps100 amp out->cabinet.
pbc10 loop7-10 delay reverb pedals etc.pbc10 out a、b->2902 ab chanel(wet sound).
Channel switching of ps100, loop switch, use pbc10 control.
Now my problem is this connection, whether I open or close the loop of the ps100, there will be a wet sound from 2902.
I use mesa mark v, orange jimroot #4,same signal chain,same situation.
If i use amp`s loop,not use ps100 loop, this won't happen.
Can you give some advice, what is the problem, even if the loop of ps100 is closed, will there be a signal overflow?
My signal chain:
