Hi Folks:
I'm a noobie with loop switchers and now a proud owner of a Effects Gizmo.
I would like:
- to have FX Gizmo control my Wah, Compressor, etc... IN FRONT of my Carvin Pre-Amp.
- to have FX Gizmo control effects in the Carvin Pre-Amp's Serial EFFECTS LOOP.
- to have FX Gizmo SWITCH between my Carvin Pre-Amp and my Zoom 9150 Pre-Amp.
- where's the best place to hook-up the VOLUMN CONTROL from Wah?
- will I have "CLICK NOISE" in my Pre-Amp's serial Effects Loop that FX Gizmo is controlling since there is no "CLICK STOPPER" circuit in that loop?
- I've connected loops 5-8 to isolated loop 10 and have in turn connected the IN/OUT to the Carvin Pre-Amp's Serial Effects Loop. This lets me ACTIVATE/DE-ACTIVATE the loop by just turning ON/OFF Loop 10 on the Effects Gizmo.
- I've done the same senario with loops 1-4 for my FRONT OF AMP effects and have connected it to isolated Loop 9. SIGNAL comes in and is connected to Loop 9' IN, Loop 9's SEND is connected to the BUFFER Circuit and goes through Loops 1 - 4 and OUT back into Loop 9's RETURN. Loop 9's OUT is then connected to the "CLICK STOPPER" which then goes into a configuration using the isolated loops for AMP Switching.
Just need some opinion, comments if there is a more easier way to do this as it looks complex.
Any help before I actually begin creating cables would be greatly appreciated.
Thank you in advance for any help.
UPDATE: I've come to a design that I finally like! Here it is:
And here's a photo of the rig when I started designing the signal path. A lot has changed as I have added a Zoom ZFX2000 for the Zoom 9150's external effect loops, the SM-Pro 1U DI-8 has been removed and the stompbox/pedal tray still not installed.
I would like:
