Question: Expression Data
It looks like that unit accepts standard CC messages, so yes, the PBC/6X should be able to control it.
That's good news! I'm new to the RJM PBC/6X and am still sorting things out -- can the PBC/6X generate saw-tooth-like or circular oscillations as CC messages? Which section would I go to in order to do just that, if so? For example, on the OBNE YT channel they're using 4 LFO's (from Ableton Live? or SurgeXT?) to generate the demonstration MIDI CC's:
Currently it doesn't have the ability to auto generate CC message streams, you can only generate them via expression pedal moves.
Hmm... I'm wondering if there is a workaround to do this with the PBC/6X. I noticed that here in this video from Mark Johnston from 21:47 to 24:17, he is using this other MIDI controller's tap tempo function to generate the waveform. Is there an existing way to do that with the PBC/6X?
