vatore3rd
I am exploring the EXP Switch Pos to turn on a loop at a certain point in the expression pedal sweep. The basics work nicely. However, I am unclear as to the expected behavior of the current expression switch state when swapping expression pedal settings while the exp switch state is on.
Is the exp switch state supposed to carry over when changing exp settings? That is, will the switch actions of the newly activated exp setting fire if the pedal is above the switch position when it is activated?
