Quick Question On "In 7-10"
Realdealblues
Hello, just wanted to be clear on this.
The Mono/Stereo Out button creates a pseudo "Stereo" signal from what I am reading, so would I be correct in assuming that the "In 7-10" jack is not a TRS Stereo "IN" so you can not feed Loops 7-10 with a stereo signal, correct?
99% sure I am correct there but just wanted to make sure.
Thanks
You can run a mono or stereo signal to the In 7-10 jack.
If the Mono->Stereo button is in the out position, the tip of In 7-10 is connected to both sides of the stereo signal path, creating a pseudo stereo signal.
If the Mono->Stereo button is in the in position, the tip and ring of In 7-10 are connected to the left and right sides of the stereo signal path, respectively.
Awesome! Was curious if I could have a stereo pedal not in an actual loop before loops 7-10 or not. Guess I can! Thanks for your quick response!
