miketriple
Hi everyone ... Just a quick question about getting my two amps switching together. They sound monstrous together but just need to stop tap dancing for my switching.
I have purchased the Rack Gizmo with the RJM custom cable for the Dual Recto running out of the AMP 1 switch on the back of the Gizmo. My other amp is a Matchless Independence 35 head with reverb - this amp is currently not set up to switch. The amp is a 3 channel head which uses a 1/4inch stereo cable to run the channel change 2 button footswitch - no buttons pressed = channel 1, 1 button pressed = channel 2, and both buttons pressed = channel 3. The reverb is a separate mono footswitch.
Am I able to use the AMP 2 switch on the back of the gizmo to do this if I get a custom cable or will I need to use the loops?
With loops 5 though 8 being stereo does this mean I just need one stereo cable from the out of the loop to the footswitch in?
Or will I need to use 3 of the loops separately?
