Chrysalis99
So I’ve been like a kid in a candy store with this new pedal. What a home run this is and it’s more then just a drive pedal. Is it safe to assume the most recent firmware is already installed?
Two things to check: first, on Macs, the pedal works best if you don't power it up with a power supply and let it draw power from the USB cable. Second, not all USB C cables will do the job. The one that comes with Mac chargers, for example, is a charge only cable and doesn't transfer data. Also, using a USB hub may help. Please give all this a try and please let me know what works (if anything).Can't seem to get the pedal recognized on MacBook Pro. Says no device available when trying to connect with the pedal editor.
Great! For some reason, Apple products are really picky about USB C, and I haven't yet figured out why.Power supply was the issue. Connected immediately as soon as I used the cable only. Looks like I’m on the most recent firmware.
The editor is real snappy. Instant changes on the Overture. Faster than MIDI.
It’s a great pedal. Likely to bump a drive pedal off my main board. The clean boost is particularly good but that’s only a small part of the story. There’s a lot here.
