Reordering with Mini Effects Gizmo X
franktree
If you daisy chain two (or more) Mini Effects Gizmo X's together, are you still able to change loop order between any loop within both devices, or only within each individual device?
Loop order would only be within each MEGX. You could however put one MEGX in the loop of the other allowing you to put it at any point within that device. This would mean the 6 stereo loops could be put anywhere in the chain of the other MEGX's loops position. Does that make sense?
i.e.
MEGX1-Loop1-Send into MEGX2-Input
MEGX2-Output into MEGX1-Loop1-Return
Then MEGX1-Loop1 could be moved anywhere in the chain for MEGX1 allowing MEGX2's loops to be moved around, like at the start or at the end etc.
