Resetting Cycle buttons
AlexMania
Hi Communal brain,
I use cycle buttons and at times would like inactive cycle buttons to reset to step 1 when I step on another cycle button. I Know Cycle buttons can reset on preset change. Can they also be reset via a system command (like turning to page X)?
Alex
Wow, your timing was excellent! Groups will now do that, as long as you don't mind the relationship affecting each cycle button in the group - pressing any button will reset all others in the group to step 1.
You can also use the System / Set IA action to affect the state of a cycle button without grouping it. Set the IA ID of the cycle button to something other than 0, then on the other button, put a System / Set IA #x off:None on:0, where x is the IA ID. When the button is activated it will set the state of the cycle button back to step #1.
