Hello,
I have some questions that I'm pretty sure are easy to answer but I simply can't get my head round them.
I'm currently using RG 16 as an audio looper and not so much for its function switching. I'm using a MIDI controlled amp as well as a number of pedals connected to the RG 16. One of them is the Eventide Time Factor which as you may well know is also MIDI controllable. So the RG 16 controls the pedals and it's connected to a Voodoo Lab Ground Control Pro which also controls the amp. Each device is set in a different MIDI channel and the RG 16 is identified in the GCPRO as 'GCX' (it's taking the place of a Voodoo Lab GCX switcher).
What should the MIDI connections be in order to make it feasible to program and control everything (the RG 16, Time Factor and amplifier) via the Ground Control Pro?
Looking forward to your replies,
Euripides
Euripides
