I'm hoping someone can give me some guidance with a hum issue I'm having. I've tried a few things on my own, but I think at this point I need some expert advice. It's probably a ground loop issue--I don't think there's anything wrong with either the RG-16 or G-Force--but I'm kind of out of ideas right now.
I recently changed amps and ever since then, my G-Force has been humming loudly whenever I activate the RG-16 loop (Loop 7). Prior to this, it had always run quietly. My new amp is a Koch Powertone II, just in case that's relevant. Every other piece of equipment, including cables, remained unchanged and in the same locations; I just switched amp heads.
Here is some info as well as some things I've tried:
*G-Force is mounted to the rack with Humfrees, as is all other rack equipment.
*G-Force and Rg-16 are both powered from a Furman conditioner
*Hum is present only with the G-Force. I've tried some stompboxes (in the same loop) and there is no hum with them.
*I tried the G-Force in another loop (Loop 6) and there was still hum.
*There is no hum if I take the G-Force out of the RG-16 loop and run it directly in the effects loop (G-Force is the only thing in the loop)
*Hum is present when G-Force is removed from rack but still run through Loop 7
*I've tried other cables between the RG-16 and the G-Force and the result is the same
*Hum is present even when G-Force is powered off (but Loop 7 is active)
*I've tried an Ebtech Hum Eliminator between the Loop 7 Send/G-Force input as well as G-Force output/Loop 7 Return. In both instances the hum still remained and the signal sounded much weaker.
Thanks for taking the time to read this. Looking forward to any advice you all might have for me.
