infantryman
Hi everybody!
I controlled my Dual Rectifier (3 ch.) and my G-Major with my Mini amp Gizmo via a Roland FC-300 Midi foot controller in ''Standard'' mode. But, I tried to switch in ''Patch'' mode to fine tune & choose specific options in my rig.
For exemple, I know that the switchs 1 & 8 on the Gizmo switch the Mesa Clean channel and turn the effects loop On.
I programmed in my FC-300:
Patch Mode:
Midi ''On'': PC 01 / Ch. 01 / CC 088 / Value 064 (Gizmo Switch 1 On)
Midi ''On'': PC 02 / Ch. 01 / CC 089 / Value 000 (Gizmo Switch 2 Off)
Midi ''On'': PC 03 / Ch. 01 / CC 090 / Value 000 (Gizmo Switch 3 Off)
Midi ''On'': PC 04 / Ch. 01 / CC 091 / Value 000 (Gizmo Switch 4 Off)
Midi ''On'': PC 05 / Ch. 01 / CC 092 / Value 000 (Gizmo Switch 5 Off)
Midi ''On'': PC 06 / Ch. 01 / CC 093 / Value 000 (Gizmo Switch 6 Off)
Midi ''On'': PC 07 / Ch. 01 / CC 094 / Value 000 (Gizmo Switch 7 Off)
Midi ''On'': PC 08 / Ch. 01 / CC 095 / Value 064 (Gizmo Switch 8 On)
Midi ''Off'': PC 01 / Ch. 01 / CC 088 / Value 000 (Gizmo Switch 1 Off)
Midi ''Off'': PC 02 / Ch. 01 / CC 089 / Value 000 (Gizmo Switch 2 Off)
Midi ''Off'': PC 03 / Ch. 01 / CC 090 / Value 000 (Gizmo Switch 3 Off)
Midi ''Off'': PC 04 / Ch. 01 / CC 091 / Value 000 (Gizmo Switch 4 Off)
Midi ''Off'': PC 05 / Ch. 01 / CC 092 / Value 000 (Gizmo Switch 5 Off)
Midi ''Off'': PC 06 / Ch. 01 / CC 093 / Value 000 (Gizmo Switch 6 Off)
Midi ''Off'': PC 07 / Ch. 01 / CC 094 / Value 000 (Gizmo Switch 7 Off)
Midi ''Off'': PC 08 / Ch. 01 / CC 095 / Value 000 (Gizmo Switch 8 Off)
Off timing: Patch change
On the Mini Amp Gizmo: I make sure that the Midi channel is 1. (Hold the Switch 1 and Power On the Gizmo until the Leds flashed. I made sure that the led's 1-2-3 & 4 didn't light on. I pushed on the ''Write'' button.
It is not working! Somebody can help me please?
Thank you!
Patch Mode:
Thank you!
