Ralf Conrad
I just got my PBC and it looks very promising. I've run into an issue with the use of a tap tempo button. As far as I understand it, there are two ways to accomplish tap tempo:
1) I set up a button to IA, assign a new CC-tap tempo action for every device I want to control and it will send the corresponding command. However, when I press the "flash w/ tempo" button, it will always show me the preset tempo. Right?
2) If I want to tap midi clock instead of CCs I follow this guide:
http://www.rjmmusic.com/forum/index.php?threads/setting-function-button-to-tap-tempo.1848/#post-7499
If I understand correctly, there is a button assigned to IA without actually any IA action assigned to it. Only "flash w/ tempo" checked is enough to tell the PBC that it's a tempo button. However, when I hit that button, the PBC still keeps flashing with the tempo assigned in the preset.
What am I doing wrong?
Thanks,
Ralf
Thanks,
Ralf
